Gas Giant
- Aug 8, 2010
- 239
Engine is a '61 Evinrude Lark III, 40hp, model# 35524. The lower unit seal kit is Sierra 18-2686.
Okay, short story long, I am in the process of re-sealing the lower unit on my motor since I got a bunch of water out when I drained it. I picked up a seal kit, Sierra P/N 18-2686 thanks to this forum. However, I did a search and didn't quite find the answer to this question. (Or I did a bad search, we will see
Everything was going well, (thanks to my PDF manual and iBoats posts!) but on the prop shaft there is a seal retainer, and it has 2 seemingly identical seals installed in it, back to back, sort of like this ][. However, my seal kit only came with one of those seals, and looking at pictures of the contents of the kit online I don't think it comes with the 2nd one. (At first I thought maybe a factory worker somewhere let kit one slip through the cracks with only one seal). My manual doesn't mention a 2nd seal, and the parts breakdown on marineengine.com only shows the one seal with a quantity of 1 - no 2nd seal.
So, I am calling upon the infinite wisdom on this site for advice. Is it only necessary to replace one seal? Both of the seals in the retainer look decent, and are still pliable (not hard and cracked like the transmission tailshaft seal on my Bel Air was :redface
If so, which of the two seals should I replace? The one towards the propeller or the one towards the gears?
And, any helpful hints on removing one seal without harming the other?
Thanks guys!
For reference, here is the retainer and new seal in a bad photo I took:
Thanks guys!
