2 small gaskets in Alpha1 Gen2 water pump kit?
Dshow
There are two small gaskets that are the same size that are included in a water pump repair kit for an Alpha 1 Gen2 outdrive. (Right below the pump housing in the picture) Where do they go?
Thanks-
Don S
Re: 2 small gaskets in Alpha1 Gen2 water pump kit?
Drain and vent plugs. The one on the left is the quad ring that seals the oil passage between the upper and lower. DO NOT forget to install it.
Dshow
Thanks Don, good answer... I had those left over and wasn't sure where they went. I can put them on it the spring. (I got the oil passage gasket)
