No more boats
- May 4, 2023
- 62
2000 OX 66 =250 hp - 2 stroke
yesterday , pulled boat , pulled drain plug
water coming out was clear , then oil was mixing with the water with a smell of gas coming out ?
Never had a problem with 2 stroke oil system
gas is returning & over filling 2 stroke external reservoir . ( reason for oil/ fuel in bilge ) tank was overfilled with oil & fuel coming from top and where tank is mounted it runs off into bilge
Engine oil tank had gas mixing also
Making a complete loop of the oil system
realize i can run 50 :1 oil mixture by passing but want everything working as it should
what would cause the fuel too come back too oil reserve then fill engine oil tank ?
oil pump ?
inside vst tank ? stuck float
check valve ?
this issue must have happened on return too port cause hour earlier my head was in bilge and everything was fine , I was off shore close too port
some thoughts is appreciated
oil pump ?
check valve ?
