2 stroke synthetic blend oil
stormmn
Hey guys
found Quicksilver TC-W 3 synthetic blend oil at Wal-Mart for $4 more than the regular QS tcw 3 oil per. gal.
my question...
I have a Merc. 2 stroke oil/gas mix older engine that smokes like all 2 strokes at idle and low throttle, will this synthetic oil eliminate or help with the smoke screen????
thanks
Silvertip
Re: 2 stroke synthetic blend oil
Semi-synthetic helps, full synthetic helps even more.
stormmn
silvertip
where have you seen TCW 3 full synthetic oil...
I have looked under search engines and never seen this?
thanks
robert graham
Check Pennzoil 100% Synthetic Outboard Motor Oil at Walmart($27/gallon), I've used if for several years in my Yamaha 90HP 2 stroke premix motor and there is very little smoke, less carbon, clean burning. Good Luck!
stormmn
sorry guys, guess I have been in the bubble house, I went on line and found four brands of full syn. oil available.
As for the Penzoil brand at Wal-Mart, it may have been on the shelf but from experiance as a mechanic at a Pontiac dealership back in the 60's & 70's, I do not even look at a Penzoil product. as the old saying went, I wouldn't fry a rotton egg in Penzoil.
If you did not change oil & filter every 2000 miles it turned to sludge big time.
Ya I know, that was what 40 yrs ago......
thanks again for the information
