2 vs 4 Barrel Carbs
rlb2252
A question regarding the Mercruiser 260. Does it come in both a 2 barrel and four barrel configuration? And if so, is there a note worthy mpg disparity between those two variations?
legoman67
Re: 2 vs 4 Barrel Carbs
easy way to check, with the engine off, pop the flame arrester off and push on the throttle and see for yourself.. do you see 2 or 4 barrels? pretty sure most mercruisers v-8's are 4 barrel
rlb2252
Actually I don't own the boat yet. Just considering it.
legoman67
they could have either, most likely 4 barrel
Ayuh,... 260 is the Horsepower rating,... That's with a 4bbl. carb...
If a 2bbl. carb is installed,.. It'll be Less than 260hp...
So to answer your question,.... No...
proxyx
Banned
roughly 30-40% difference in mpg between v6 and v8, I own both (different size boats)
fishingman220
in 96 (thats my year) they made a 210, 230, and 260hp, and the 210 was a 2bbl, the 230 was a 4bbl and the 260 was 4bbl and different cam. i am not positive on this but it is what i have heard from a few people.
