20/25hp 2 stroke merc carb difference
boater1234
Master Chief Petty Officer
Ok,here we go on this carb issue i have.I have a 1993 20hp 2 stroke merc with the original carb of course which states the number 32 on it.I look at the 3 different carb numbers online and there is WMC 31/32A and plain 32.
All 3 carbs seem no different as in what the schematic shows,i mean no difference.So i upgraded from the 20hp carb to the 25hp carb,the yrs were almost the same,the used carb i got was from a 94 and my carb was from a 93 but i mean they are 100% identical except for the bigger bore for more power but here is what i noticed.The 20hp carb i have says it's a 32 and the carb i just got says it's a 31A but they are 100% identical from what i can see.My question is what is the difference between the 32 and 31A if they look i mean identical besides the size of the bore.I called the place i was going to buy a new carb from and all 3 numbers come back to the same schematic which shows the parts to be identical so what's with the number difference?
flyingscott
Don't worry about it. If you looked up how many different carb#s there are for that motor over the years it would astound you.
boater1234
I called the maker of the WMC carbs and he said all I need to do is swap them out and you should be good to go as he looked all 3 up for me and explained it could just be a minor thing they do to them that changes the number but they should still work. I have another forum I go on to and one of the guys said I have to redo the timing but I asked the guy and he said you don't need to do anything but swap them out and you should see a power difference more than anything, maybe a bit more wot speed he said but don't expect but a few mph at best which I figured.
flyingscott
That is right. Not a good idea to play with timing on that motor as the 20/25 have the same for timing. I have made that conversion a bunch of times.
boater1234
Awesome, so I'm rebuilding the carb today and I'm going to test how it works next week, can't wait. Ty for the great info. I will post how it comes out.
