attorneystone
- Jun 12, 2015
- 4
I will admit it. I am a dummy for getting myself into this one. I was connecting the battery on my boat and accidentally connected the ground wire to the positive post with the positive cable. I fried the ground wire from where the harness connects to the engine all the way to the ignition switch. I ran a new wire. Someone suggested to disconnect the regulator and see if the 20 amp fuse would still blow. When I went to disconnect the regulator, the rubber covers at the connections were all stuck together from getting too hot. So I replaced the regulator thinking it was fried as well. Now atleast I can turn the key to on and the gauges will work as well as the choke. As soon as I try to start the motor the fuse blows. What else am I missing?
