20 hp Coughing
NathanY
My 1974 20 Hp Merc is coughing on idle, does not do it when you wrap it up, just at idle, and idles rough. I can not find an idle adjustment screw, but the manual does show one, and I can not find a fuel mix screw although the my manual shows one of those too.
NathanY
Re: 20 hp Coughing
Yep that looks like my carb. See where it says that there is a fuel mixture screw and a idle screw? Mine does not have one or I am not seeing it. I let it run for about 20 minutes on muffs. as long as I have the choke 95% open it runs fine. But Dont think that would be closed enough to matter. I am going to take it out tomorrow and run the dog out of it. I has been sitting for 10 years. Carb has been rebuilt.
12Footer
Re: 20 hp Coughing
Sneezing is probably not caused by a carb problem. And here is somethuing to consider...the carb was fine before exactly where it's adjustment is now. I would suspect the plugs, ignition, or small amounts of water injestion.<br />Pull the plugs.If one or both are spotlessly clean, it may be water injestion. If they are nasty, replace them.<br />Plugs on the 2 cycle outboard do not hold-up long, and many manuals sugest replacement around the '80hours of operation' mark.
Walker
Re: 20 hp Coughing
I beg to differ. Sneezing is usually caused by a too lean condition. If you carbs doesn't have a mixture adjustment then you need to give the carb a good cleaning paying special attention to the idle jets.
NathanY
Re: 20 hp Coughing
I just relplaced the plugs with Champion L78V. The old plugs where not right, they had J electrodes on them, but they did not look bad at all. Both plugs are firing, a beautiful blue flame.
