ahicks
- Sep 16, 2013
- 3,957
What I'm looking for, honestly, is somebody with the same or similar boat that's already tried a couple props? What were your results? What did you end up using?
Finally picked out a pontoon boat (private individual), and on the test drive I see I've joined the "it's only showing 4k on the tach" club? Engine seems to be running fine. I get the fact there are different pitch props available, and the difference in rpm's resulting from a pitch change (been boating many years).
This is a low time boat and I'm assuming it still has the original prop on it because the original owners never wanted to take the trouble to dial it in properly. I played with the trim and that really didn't produce anything meaningful until I went out too far with it, causing the rpm's to finally jump way up but obviously cavitating.
Boat will nearly always be lightly loaded, never pulling anything (thus the smallish engine).
I've spent hours searching through the prop forum and this forum which didn't really give me anything I'm willing to bet on. Have been on the Godfry/Sweetwater website looking for some insight on this boat/power combo for prop guidance, as well as Honda's site. All I see are lists of available props. No recommendations for a good starting point.
Thanks for any help/ideas!
-Al
-Al
