200 johnson no spark on cylinders 2 & 5
Status
Not open for further replies.
tampaaquasport81
Re: 200 johnson no spark on cylinders 2 & 5
i looked in the marine store and could not find a repair manual for my motor, only the cdi repair manual. where is a good place to pick up an oem manual?
CapTWilly1127
I have a similar issue. I have spark on all 6 when i start it. After it gets warm i lose spark on number 2. I swapped the power pack wire from the ignition coil to another one (swapped) and then #2 started to fire and the other one went out. This tells me the ignition coil is good, plug, and wire are good and the problem is following the wire off the power pack ---> to what ever ignition coil i move it to.
If i turn the boat off a number of times and back on, it will pick up. I have cleaned every connection, and everything looks good. I am trying to determine if the power pack is failing or if this is timer base related.
Status
