What show the compression be on a 200 Hp Mariner <br />outboard. 1983 is the year.<br />Thanks
B badbrad Recruit Joined May 3, 2003 Messages 1 May 8, 2003 #1 What show the compression be on a 200 Hp Mariner <br />outboard. 1983 is the year.<br />Thanks
K Kenny Bush Chief Petty Officer Joined Mar 24, 2002 Messages 564 May 9, 2003 #2 Re: 200 Mariner Should be around 125 psi......
country boy Seaman Joined Dec 20, 2002 Messages 61 May 22, 2003 #3 Re: 200 Mariner for a 1983 unless it has very low hrs you may see this type of compression ,also as long as there is not more than 10 to 15 psi difference between any of your cylenders,you should be ok unless it is extremely low , good luck
