Is there a mane fuse some where near engine, all fuses on side of engine show no voltage.
R riich Monterey Recruit Joined Jun 22, 2018 Messages 3 Jun 27, 2018 #1 Is there a mane fuse some where near engine, all fuses on side of engine show no voltage.
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 51,664 Jun 27, 2018 #2 check your battery connections
legalfee Chief Petty Officer Joined May 10, 2018 Messages 407 Jun 28, 2018 #3 Your fuses are in the Power Distribution Panel on the starboard side of the motor. It is a black plastic cover that has two silver screws holding it on. You can use a dime to loosen the screws. There are 7 mini-blade fuses in there, all 10 amp.
R riich Monterey Recruit Joined Jun 22, 2018 Messages 3 Jul 1, 2018 #4 Thank you,main fuse has power 12volts .but all fuses have none , testing with key on, please help.
