I'm having a problem with my Port engine. I can cruise for awhile at say 2000RPM and then suddenly the Port engine goes to 0 RPMs and then after about 1 to 2 seconds goes back up to 2000 RPMs. (this can actually happen at any speed) It did this for a couple of outings, once or twice per outing. Then, when it did it again, I would have to restart the engine, as it didn't come back by itself. Did this a few times, and then finally I couldn't start the engine (wouldn't turn over). My marina mechanic said he found it water locked which he fixed and replaced the PCV valve (check valve). He thought he solved the problem, but it just happened again this weekend. Last fall they had to replace the distributor and coil on the starboard engine, but for some reason didn't do that on the Port engine. I think they should have done both and have instructed them to do so.
Anyone got any ideas as to what might be causing this?
Thanks
Thanks
