2000 j90pls are idle mixture screws
143brad
I'm working on a 2000 j90 PLS I have read numerous blogs about setting the idle mixture screws all the low Side from being tooth turns out to 5 and 3/4 I've come to learn mine or 10 turns out is this normal or should I start over could somebody help me thank you
oldboat1
Not sure what you mean. Are you saying the motor runs at that setting (10 turns)?
143brad
Yessir I recently found out that my hoses had gummed up so I took the carburetors apart had them all cleaned and everything and my low speed idle screws were turned out 10-hole turns and I have read where some people said start at 5 and some people said two the reason I'm asking is because when I modeling out to the lake it runs a little rough so I did not know if that had anything to do with it or not
oldboat1
If it's now running well except for the idle, readjust the needles 1/8 turn at a time, and test. I would start by adjusting clockwise (leaner). If the engine stalls or coughs (lean sneezes), adjust 1/4 turn counter clockwise and test -- may be close with that setting.
143brad
Okay I will try that my main concern was I didn't know if it was normal for them to be 10 whole turns out I didn't know if that was causing it to run to Rich thank you sir
oldboat1
Yes. 10 is too much (would be like running without the needles, imo). Sounds like an attempt to correct other carb issues.
good boating to you!
Faztbullet
Set em 5-1/2 turns out from a light seat, engine has to be in water,warmed up, trimmed level and in gear to adjust..You can get it close leaving it on trailer.
