2000 jeep wiring help?? please
solidwaste75
I put in an aftermarket hitch today and am now trying to wire the lights in..The wiring on my chiltins manual is not what I have at the taillight I put a tester on the plug but when you pull the plug on the light it kills the power to it so I dont know how to find wich are the right wires to hook to..Has anyone had to do this to a 00 grand cherokee and possibly know which wires are what? Thanks for any help...
djvan
Re: 2000 jeep wiring help?? please
I wired a 2000 cherokee sport, used the wiring harness from the dealer parts counter, worked great for 3 years (traded it in at 3 years). I would imagine the grands are similar.<br /><br />DougV>
TilliamWe
Banned
solidwaste, at a recent "vehicle fire seminar" I attended, it was stated to us that U-Haul, when installing their hitches on Grand Cherokees, is putting a fuse on the wrong side of something. And causing the wiring to melt, and they have started some fires, all minor so far. What does this have to do with you? Well, maybe nothing, but I wanted to advise you, just in case, don;t ask for U0Haul's help. And don't copy their wiring, in case that was an option.
Silvertip
The first thing you have to determine is whether the brake lite and turn signal use the same bulb, or if they are separate bulbs. If they are separate bulbs, you need to by a converter. There is no way to make the lights on your vehicle work with the four wire system on your trailer. If a single bulb is used for both brake and turn signal you don't need the converter. Head to your local auto store or home store that sells auto parts and buy the plug-in harness. You unplug the chassis harness at the back of the vehicle, insert the trailer harness and your done. Quick, simple, and water proof.
jpg
I have a 2000 Grand Cherokee and did the same thing with a aftermarket hitch. I also bought a converter from the dealer that sold me the hitch, it just plugs in the wireing harness behind the inside left quarter panel.
Lou C
I did the same with my 1998 Grand. Just use the dealer stuff, it is all plug n play with no worries!
