BartJohnson
- Jul 21, 2022
- 2
I have a 2000 Johnson 150 two stroke that's making me want to pull my hair out. Four years ago I replaced the VRO pump. And then the boat sat for... a bit. This year I replaced the external fuel lines (it's on a Glastron runabout and I didn't know how to get at the internal fuel lines that ran under the floor at the time). I took the boat out and it ran better than it had in years... for an hour. Then I barely was able to nurse it back to the dock, wouldn't idle, stalled out as soon as I got it in gear, etc. Once I got it back I realized (try not to laugh) the gas in the boat is probably almost four years old. (had a kid, problems at work, started camping a ton because of COVID, yadda yadda, I know. I'm an idiot).
I drained all the fuel. I put in five gallons of non-eth along with a pint of seafoam, towed it around a lot to try and slosh around in the tank, and ran it through the primer bulb to a waste tank to try and clean everything out. Drained all of that, cleaned the carbs with carb cleaner (not removing them, just cleaning in place), and put fresh gas in. Again, the boat ran great, in the yard. Got to the lake and I again could barely keep it running and it was smoking blue like crazy. I'm fairly certain it's getting too much oil, but would that really cause it to barely run?
I did a compression check and I got 120, 120, 120, 120, 110, 110 (both low numbers are the lowest two cylinders).
I'm tempted to rebuild my old VRO and install it, but am I missing something here? Can a VRO pump really go bad with less than 20 hours on it?
None of the shops locally can look at it for a month.
