Ran engine aproximately 2 1/2 hours Tues and Wed, no problems. Same tank of gas (1/2 tank left), same oil (about 3/4 tank left) different day, today. Engine initially fired up then quickly stalled, with alot of white smoke noted. Tried again, cranked up and advanced throttle quickly this time. Engine would not tach above 2200RPM, with throttle about 3/4. NOTE: This normally is about a 3500 RPM setting while under way. Still alot of whitish smoke running very rough, and stalled as soon as I thought of pulling throttle to idle. Changed out all 4 plugs, and noticed a large amount of oil on each. With spare plugs in, engine cranked right up again with same result. Very rough, not able to get RPM's above 2000-2200, alot of smoke and stalled out as soon as thottle started toward idle. WHAT IS WRONG? HOW DO I FIX IT? IS THIS A SITUATION TO BY
PASS THE INJECTOR AND GO TO PRE-MIX?
