Re: 2000 Mercury xr6 150 Overheating
Yes Sir, you will have to pull lower unit. It's not a tough job at all, just beware of hidden bolt underneath gray trim tab, you will have 6 bolts total to remove/loosen, and she'll slide down with no problems.<br />If you can purchase an impeller kit (includes gaskets) it will be better, and don't toque pump bolts too much, housing is plastic, and can break easily. Also watch speedometer pickup tube (a tiny small plastic tube in front of unit) which could came loose and or break, lower unit so you can access it, then disconnect it (remember to re-connect it, or it will leak water and you won't have any speedometer reading)<br />Once you do it, you'll decide like I did, to replace it every year, it's a $ 25 job that saves thousands.
