2001 225 optimax won't start
JamieCounter
hello everyone new to forum , I'm having an issue with my outboard i started the motor the other day and it started right up so it let it idle for a few min. water pump was working good ! . so i wanted to idle it up a little so for what ever reason i pushed the button as to not put in gear and pushed the lever backward as in reverse the engine started miss firing , so i turned engine off put it back in neutral and tried to restart engine with out success it cranks wont start i have spark when cranking engine i have 80 psi on air side and 85 psi on fuel side and i have also put in new plugs i checked fuel pressure at high pressure pump and it makes well over 100 psi not boat was siiting for probably six months thanks for any help
oldboat1
How much spark? Each measured with an open air device?
Think I would check for continuity on each plug wire, end to end -- also might pull the flywheel and check for loose or damaged magnets.
JamieCounter
problem solved the fuel sysem just needed to air purged once that was done it fired rite up
Chris1956
You might post questions about Mercury Optimax in the Mercury OB forum.
