2001 496 Mag Ho
Styner
Im having a voltage problem at the engine, will not start bit will turn over. I have main power at main breaker, fuse at starter is good, 3 20 amp fuses and only have power to one fuse when battery switch is turned on. I also don't have ignition power at data link port. I have ignition power at bus connector on both sides. Im lost at this point, any help would be appreciated.
2001 496 Mag Ho
alldodge
With Bat switch (k) on you should have 12V at the Main Power Relay (l), fuse between c and d, fuel pump relay (g) at pin 30, alternator (f) sense lead and pin A of the DLC (e) connector
What is the buss connector your referring to?
Styner
Main harness plug back of motor, harness feeding helm. Which would be power and ground to dash and then ignition and start.
