No fuel coming from injectors while cranking fuel is at the injectors and pressure is good
Starts with starting fluid
Crank with a noid light no light
I have 12v on each side of the two injectors with key on
When you try to start ....when the you turn the key to on .....the noid flashes one time dimly
I have taken apart all connectors and checked all grounds
When you 1st turn key on all sounds normal and fuel pump pressures up
I replaced the control module in the distributor
Help ,,,, but
Help ,,,, but
