2001 Evinrude 115hp FICHT not holding fuel pressure.
Yungster1972
My motor is hard to start. I can get it on a plane but it stumbles getting there. I connected it to my computer and adjusted the injector mixture toi as rich as it will go and the motor ran alot better so I checked the fuel pressure. My motor will not hold fuel pressure. I turned on the ignition several times, I can hear the pump and them I check pressure at the fuel linf schrader valve and I get very little to no pressure. With the boat running I get 25psi. Any idea what could be the problem? Thank you for your time.
