2001 Rinker 192 dead dash
Doug Money
I have a 2001 Rinker Captiva 192 with the VDO gauge set. It quit working and Rinker tells me I need to replace it with the normal gauge set that was used before and after 2001. It really irks me that they tried out this dash and us owners get to pay for their mistakes. Is there a way to salvage what I have or do I need to go the route of replacing the dash? Has anybody here done this already? Just wondering how complicated it is. Thanks for your help.
Doug
Frige
Re: 2001 Rinker 192 dead dash
Hey Doug,
Is this a digital dash or does it have the analog gauges? Have you checked to make sure you have power going to the dash?
Doug Money
Yes, I have the digital dash. I checked and I have constant voltage to the dash.
ventilex
Doug:
I have a 192, 2001 with the VDO. I had this problem twice. If the clock is working, then the fix is somewhat easy.
If you have power and the clock works, the issue is most likely the foil push buttons. There are 3 mylyar/foil wires from the 2 push buttons. What happens is that the dished metal idomes inside the push buttons eventually move inside the laminated push buttons and short out the button like it is constantly being pushed. When you power up the dash, it goes through a self check, and if the button (or both )are pushed, the guages never boot.
To see if this is the issue, disconnect the switch by removing it from the head unit. There is a clip that the mylar wires go into. If when those are removed, and the guages work, then email me and I will tell you exactly how to repair the push buttons. Unfortunately, I could not find a replacement for the push buttons, and I even spoke directly with Randy Rinker and he did not know where to find them either.
If pulling the wires off does not work, then you have some other issue. But I have helped at least 10 people with this exact issue, and each time it was with the switch.
If you have no power to the clock, the issue is at the engine at the big red reset button. I had that occur once, and some cleaner did the job.
If you ened the electrical manuals, email me also - I have them in PDF
Tom - tom.schroeder@ventilex.net
2001 Rinker 192 Green on White with Trim Tabs, 14.25 x 20 Stellito Prop
