plyons7890
- Apr 14, 2014
- 2
Thanks to anyone who can give me some insight here. I am no mechanic.
2001 Stingray 180 - stalls out when going anything over no wake speeds - usually.
Took the boat to a marina for repairs. Fuel pumps been changed, and they found water in the gas. They emptied 20 gallons, and added 10 gallons of good fuel.
Boat starts right up cold - idling is no issue - around 900RPM. Most times I can only just go into gear and putt around. Today I took it out and sat on the water for an hour or so and the boat cooled down. When I started it back up that second time, I had full control. RPMs bounced a bit. There was a bit of hesitation, but I was full throttling no problem. I dropped back down to idle, and tried to throttle back up as a test. It stalled again. If I pump the shifter the right way it seems like I can get myself above 20k RPMs and then it's OK for awhile, until I put it back into nuetral, and try to rev up again.
Can anyone point me in the right direction as to what the next troubleshooting step be?
Thanks again
Thanks again
