Merc3.0SEARAY
- Aug 20, 2020
- 2
Hello,
I'm in need of guidance on timing an electronic ignition 3.0.
I purchased a 3.O Searay Bowrider at an auction. Quickly discovered poor compression in cylinders. 2 &;3. I replaced Complete head (cracked at exhaust bolt hole end of block 4 cyl), intake exhaust manifold, carb, plugs, wires. Cap, Rotor, Ignition Module. Big smile when got boat back but still no power to plane but advanced while running on lake with a friend and got it screaming. I was unaware of base timing and got nowhere. After some poor education google and forums and since I could not find an original manual though did purchase Solec manual not much help. I have an unusual occurrence taking place. When I begin base timing with module shunted and bypass shift interrupter as I advance the distributor the timing mark moves towards retard. I exploded my brain and thought maybe I am so far advanced I could retard with digital and move distributor a little at a time as I did this. I got back to 9 degrees and 750 -800 rpm was feeling pretty proud but when I accelerate in neutral I'm dragging not advancing or advancing to far. I did pull al plugs and have distributor at TDC1 compression (used compression tester to confirm). Having difficulty for sure. Was rich adjusted single mixing needle to 1- 1.25 and trying to get rpms down but now cant get below 900-1000, Seems I'm right there and then woof the timing mark jumps back to like 3-4 o'clock retard. I have been stepping the digital a little at time then moving distributor and digital bring back to zero the digital go again a little advance etc. Crazy that the timing moves retard when I counter clockwise move distributor. As I said I am at tdc compression number1. could pick up coil be heating and causing this?? new definition to throwing money in hole in ocean. Mechanic who wrenched the head and exhaust not good with electronics. Also I cannot unplug shift interrupter with engine running to bypass or stalls. So I assume you bypass shift interrupter, start warm up then shunt distributor module to enter base. Do you un shunt distributor before shutting down engine to lock or set electronic time or after key is off. Seems when I stall I lose all gains I've made and have to start again. My mental timing is now off. ANY MERC STERNDRIVE EXPERIENCE IS WELCOMED.
