2002 Yamaha SX150 Saltwater Series HP Fuel Pump
jb1
Has anyone ever had a HP fuel pump go out on a SX150 (2002 Saltwater Series) Yamaha? With 12VDC on the pump terminals there is no fuel coming from the pump outlet. Bad pump or something else.
Thanks
blackbox
Re: 2002 Yamaha SX150 Saltwater Series HP Fuel Pump
it is not looking good for your fuel pump. i have hard of people using penitrating oil and a direct battery connection to brake it free. if you do replace the fuel pump, you should replace your fuel filters and add a 10 micron pre-filter if you do not have one.
99yam40
Do a search for testing hp pump to make sure you are testing properly or get a manual. I am not sure about yours but some have 12 volts as long as key is on but ECU grounds to turn pump on when it wants it to run.
