New to me 2004 Glastron GX 205 only 70 hours of use.
Volvo Penta 5.0 GXI (270 hp). SX-M 1.60 gear ratio.
Current Prop - Volvo Penta #3850301 - a 14.5 x 19 three blade aluminum prop (good condition).
Boat length 20 ft
Dry weight 3025 lbs or 2845 lbs. In doing web search for 2004 Gx 205 I am finding two different dry weights. The 3025 lbs is the weight listed the most often.
I boat at higher elevations than most folks, think Lake Powell at 3630 to 3700 ft water level elevation.
Testing with the current prop was done on a reservoir at 3800 ft elevation.
Testing conditions.
Fuel tank full - 35 gallons.
People two - 370 lbs
Gear approximately 200 lbs
Water conditions were rougher than I would of liked, but I made the best of the situation.
Performance
0 - 20 mph 5.11 seconds
0 - 30 mph 8.65 seconds
Slowest planning speed 19 mph
3000 rpm = 27.8 mph
3400 rpm = 30 mph
WOT (trimmed up) - 48.8 mph @ 5150 rpm
WOT (mid trim position) - 47.4 @ 4900 rpm.
Performance areas I care about are.
Hole shot for pulling slalom skiers
Mid range fuel economy ( think cruising at 30 mph)
Overall boat handling and ride
Slow planning speed.
Having read many of the prop discussions for similiar boats here in the forum. I was looking at the Stileto stainless steel Bay Pro II four blade in a 14.25 x 18, but then I learned that Stiletto no longer has an exchange program. I was told things changed after Yamaha bought them. It was suggested to look at the stainless steel Powertech ELE series. Powertech does have an exchange program in case the first prop I order is not quite right. I was given two recommendations either the ELE 15 x 17 four blade or the 14.5 x 19 four blade.
So prop gurus what is your advice? I will be buying a prop and of course I'd like to get the best option the first time if possible. Even though the props I mentioned are four blades I am not set on these choices, so if you have a different recommendation please let me know.
Thank you in advance for your assistance!
Boat length 20 ft
Testing conditions.
Performance
3000 rpm = 27.8 mph
3400 rpm = 30 mph
