2004 OX66 225 no voltage at fuel pump
Wcs69rat
I have a 2004 225 OSX that seemed to start and run fine when I got it. Shortly afterwards, I swapped it over to a different hull. When I initially tried to start it, it would not run. I had spark and evidently fuel because when I would pull the plugs they were wet. I finally got it to stay running with starting fluid after about 30 minutes. After that, it seemed to start fine when I tried it at home with a set of muffs on it. Once i got to the lake, all it would do was turnover. It would not light off. When i got back home, i sprayed starting fluid in it and it would fire but not stay running. When i checked for voltage at the pump, i have none. Any help would be .uch appreciated. Thanks in advance.
boscoe99
The pump gets battery voltage from the main relay. Do you have voltage to the relay? Do you have voltage across the relay?
