2004 Yamaha 115 HP 4 stroke.
KLSS
Need help please, I have an 04 Yamaha 115 4 stroke, While cranking the engine over it has no spark for three to five seconds then it will start. When you first turn the key to on all four plug wires flash one time, I am using spark plug lead testers. Things that I have done so far, tried a new ECU, load tested both battery's, replaced the battery cables, replaced TPS. I hooked it to the Yamaha test program, no codes... Any ideas ???? Thanks.
99yam40
follow the testing of ignition system in service manual for your motor using the proper test equipment
