2004 Yamaha 225 4 Stroke
SCONOWALL
I have a Pursuit 3370 Offshore with above engines with 480 hours. Sunday it was 101 degrees on the water. Suddenly as I throttled back from 4000 rpm's, the starboard engine died as did all electronic gages and functions associated with it. Later, the gages came on and I was able to start the engine with all functions. Shortly thereafter it all died again. Then it all came back on and stayed on till I was docked. This has never happened before. Can anyone comment on what is the cause and where to begin troubleshooting.
rodbolt
Re: 2004 Yamaha 225 4 Stroke
start with the battery terminal connections and head aft.
if your guages lost power as well it indicates a loss of 12V.
seahorse5
A common problem with those symptoms is improper fastening of the B+ and ground cables at the engine. Remove the cables- first disconnect the battery- and look for arc marks and/or burned plastic on the terminal and cable ends.
