2005 Loadrite Trailer Maintenance
BULLWARKS
Just got a new Loadrite trailer with my boat but it did not come with a manual. Hubs have rubber covers and the dealer said not to grease them too much or it will dammage ?somehing?<br /><br />How much is too much? How much is correct? Where is the Grease fitting?<br /><br />Where can I get a manual?
Lou C
Re: 2005 Loadrite Trailer Maintenance
They have some of the maintenance stuff on line at their website. The hubs I had on the old axle on my Load Rite were the kind with the zerk in the hub cover (not bearing buddies) and the grease came out a vent port in the inside of the spindle, and wound up inside the axle. So there was no way you could damage seals unless the vent got plugged up somehow. I'd call their cust service and see if they can send you an owners's manual<br />www.loadrite.com
milkyway
I have a venture frame and loadrite axles and spindles. Using a grease gun, pump as much grease thru the zerk fitting to grease the inner bearing. The zerk fitting or "hole" is at the very end of the spindle which you will see when you remove the rubber cover. This is the only way you can grease the inner bearing without removing anything else. On the outer bearing, fill the cavity that is covered by the rubber bra and use your fingers to push it further inside. Fill up the entire cavity. A lot of grease this way instead of using bearing buddies will not cause you a problem. Always use marine grease. Jack one side of the trailer to raise the tires and manually spin the tire with the brakes. The tire should spin freely or at least 10 times. If less than 6 turns, the pads are too tight and your hub will overheat. I had a "fire-y experience due to overheated hubs. Adjust the star nuts. Always hook the trailer to your tow vehicle whenever jacking the trailer and use wheel chocks, all for safety reasons. About the rubber covers or bras, get from a hardware store or home depot those metal clamps they use in tightening rubber hose connections and use it to hold the bras. I lost 3 covers within 5 miles i took the trailer from the dealer. With the clamps, never lost one since. In salt water, I always use salt-x on the entire trailer every time and the white spottings stopped showing. Just some tips from experience. Also go to Championtrailers.com and they have brakes information. Having a trailer is just like having another boat to take care of. You need the manual to guide you on how to properly hook up the trailer to your vehicle.
BULLWARKS
Thanks for the posts. :) <br /><br />Thanx Lou C I'll call Cust Service and see if I can get the manual.<br /><br />Thanx milkyway for all the good info. :cool:
