Have a post in another forum (different site), but no responses. Thought I'd try here...
Have a 2005 MC 5.0 MPI (0w063211)- 285 hours with Alpha 1 Gen. 2 (0w549135) – seawater cooled. Over heating issue.
Here’s the story – starting it for first time after winterization. Changed oil and fuel filter. Hooked up the hose and muffs. Took some time to start, but finally ran smoothly. Exhaust became smoky (not immediately). I thought it was just burning off the fogging oil, but after a few minutes, temperature climbed, and the alarm went off. I immediately shut her down. I’ve never changed the impellor (owned for two years) – so dropped the lower half of the outdrive. I did notice the upper seemed warm. The impellor seemed fine but changed it out with a new one and a new body. Filled it with fresh fluid and started it again. Did away with the muffs and filled a huge storage container with water – big enough to submerge the lower unit up to the water intakes. Started it and overheated again. I don’t think any water is reaching the engine. I removed and tested the thermostat – checks out good. When doing so, no water poured from the cooling hoses. In an effort to move up stream, I then removed the hose from my power steering cooler and no water there.
Just not sure how to proceed. I don’t know if I have blockage, my impellor key fell off, or worse. Hoping for some methodical troubleshooting.
Thanks,
T
Thanks,
T
