2007 4.3 Volvo Penta, what are these, and why is there 2 ( on each side of block )
dizzyalpaca
Hey guys,
I am replacing my 2007 cracked 4.3 penta block with a 2009 4.3 gm block
I noticed they have these sensors on each side of the block, that look they have drains plugs? What are they used for? And do I need to run both?
My GM block I have has a huge 1” x 27mm port on one side that was used for a block heater and a 1/4” port on the other side I can install one of these sensors.
My question is, can I just plug the 27mm port and only run this sensor on the one side?
alldodge
The piece on top is a knock sensor. If the motor starts to knock the ECM will retard the timing to protect it
