No pee, I've checked the impeller but it seems fine. I have also hooked to a water hose and it pees under pressure, and also pushed water back through the pee hole thinking that i may have a clog but that didnt help either. Any suggestions?
You cannot tell the condition of the water pump impeller by looking at it. Should have replaced it as long as you were in there. Forcing water through the system is not an indication of anything. Does the tell tale flow with the engine in the water?
