2007 Mercruiser 3.0 135 hp TKS stops at higher speed
Big "G"
Recently purchased this boat and have been using the past month with no issues. Yesterday, it stopped while pulling a tube and would not start again. Towed back in and it started and worked fine today at low speed but stopped again at higher speed but fortunately it re-started. Lake location has a lot of weeds and algae (not sure if this has anything to do with the problem). I would appreciate any thoughts??
Ayuh,...... Welcome Aboard,...... Due to the fact that it does it at higher speeds,......
I'd be lookin' into the fuel delivery system, startin' with checkin' the fuel filter for clues,.....
alldodge
Fuel pump might be giving out. Check your oil level and if its coming up then the pump is leaking into the motor
