2008 8.1 Gil Fault Codes
ni7irs
I installed Volvo's Easy Connect system on both of my engines and am seeing fault codes. Where can I get a list of all the fault codes for this system? Most commonly I seem to have:
SPN: 266241 FMI 25
SPN 45 FMI 0
SPN 200705 FMI 7
SPN 32 FMI 0
SPN 12 FMI 0
Thanks!
muc
"Retired" Association of Marine Technicians...
You don't post a serial number so I can't look them up. But you can go to this website and get a copy of the correct diagnostic manual.
Donald0039
SPN: 266241 FMI 25
SPN 45 FMI 0
SPN 200705 FMI 7
SPN 32 FMI 0
SPN 12 FMI 0
Thanks!
You might want to purchase a Diacom and run it via a laptop. It's the best way to diagnose problems in a Volvo Penta.
  • Like
Reactions: mvn
Donald0039
Rinda.Com sells the Diacom. Make sure you get the right connectors. Contact the company to verify the proper connector. They are very helpful. I bought an inexpensive 11" Acer laptop to run the software on. You may need a long enough cable to get the laptop into the cabin so you can read the display in the sunlight.
They sell an all-in-one device (no laptop needed) but my conclusion is the laptop version was better.
I think a lot of dealers are using a Diacom
