flabullherder
- Dec 8, 2003
- 16
I've got a 1987 200hp Oceanrunner with a 225 power head on it. I've put on a new powerpack with new plugs, water seperator and fuel filter. Also replaced the fuel pump a few weeks ago (the non mix type, I premix). It seems to run fine (a bit hard to start at times but from what I've been able to read that can be almost normal) but when shifting forward from idle, if I push the throttle to the wide open position, the rpm's slowly rise and it takes about 20 seconds for the boat to reach full speed. It planes off quick once the rpm's crank up, it just takes forever to take off with the throttle forward. Makes the inlet a bit hairy with the outgoing tide if you know what I mean. Thanks for the help.
