ok i got a few problems im new to the boating today was first day i tested my boat in the water without ears
1. what does outboard sound like running in water supposed to some what run rough or smooth like a car engine?
2. sometimes i guess shifter stickers so couldnt get it started for the soldnoide
3. why would it not sometimes start in idle mode i had to try to start it with high idle set up and turn it down
4. it died on me
5. it was charging the battery, but after a while i noticed it wasnt charging so how do i test the regulator ? what could have caused it? and if its broken or what be the ohmage if the regulator is still good
as i bought a new stator, 2 switch boxes, temperature sender, rectictifer, regulator, so what would it caused this or what do i test for to see where the power not coming from?
6. the temperature gauge i had tested in the boat (i ordered one) but i have this one goes from 100 to 240 and it wasnt showing any and then right to 240 so i hoping its not over heating?
7. what is the spray should be for water it idels and sprays out but at high speed it it spits out some or not at all is it not supposed to be constant spray ? or is water pump no good?
8. and what is the rpms should be running at at high speed i had it at like 5200 rpms is that normal or what not when i hit waves it would reve up to 6000
so i need help here on what to test and how to test
mike
4. it died on me
mike
