201Thumper
- May 11, 2010
- 1
I bought a 1988 201 liberator with 270hp king cobra drive, seller had all the records of repairs and the drive was replaced couple of years ago. boat had a damaged 14.25x23 ss viper prop on it, I did some research over winter and four winns site said i should have 14.25x19 viper so I bought a 14.25x20 SS Raker, I just ran the boat and full throttle it topped out at 5200rpm ( WOT is 4200-4600 according to 4winns ) by the way speedo didn't work so I don't know top speed, I think it would have gone higher if I trimmed it more but didn't want to blow motor.
Ok now my question, it looks like the 23 degree prop would be the right for WOT 4200-4600, but i'm confused when drive was replaced it appears to me it is a different gear ratio then what it was built with (1:41:1 ) is that right? and if so what would it be since it looks like i have the highest or lowest ratio (however you figure it) available?
As I understand it the motor turns 1.41 turns to 1 turn of the prop, correct me if wrong
1988 liberator 4winns ratios 1:68:1 4.3 liter
1:50:1 5.0 liter
1:41:1 5.7 liter
1:43:1 460ci
1:50:1 5.0 liter
1:41:1 5.7 liter
1:43:1 460ci
