randysmith
- Oct 2, 2018
- 2
2011 4.3 MPI Mercrusier started up with no problems just spinning over 2-3 seconds until 2 weeks ago when I put it in the water. Now it doesn't even try to start. Just spins. It will spin 3-4 times and then drag for 3 seconds and then start spinning 3 - 4 times and then drag. It is not the battery. It never did this before.
Also, it is getting fuel. If you spray a little starter fluid, it back fires slightly when you let off the key. I attached a mercury spark tester to the plugs. Some fired white and a couple fired orangeish white. Whatever it is, it was sudden.
