I have been chasing this issue for a season already. Thought I had bad gas end of last season always use startron and sea foam. I ran all the gas out the boat last September and filled with non ethanol 91 with starteon. Same issue when putting in back in last earlier this week.
it’s starts fine, has no power and will
not exceed ~2K rpm until engine hits 150 Deg. If I put around the lake for half hour it will start to surge up and down then plane and run about 4K WOT. Boat use to do 4800 rpm and 45 mph. Now it barely does 25/30 @ 4K. Very much has a hesitation issue. It seems like if I slam it to WOt while warming it up it just runs like crap and is bogged down. If I walk it up over the course of 10 minutes it will usually get to 150-160 Deg and all the sudden plane and run the new norm with plenty of hesitation if you come back down to idle forward. I checked the TPS it’s good, I replaced the IAC because I did start to notice I couldn’t hear the IAC whistling until it started hitting the 4K time line and I checked fuel pressure and it’s 40 idling and 45 under throttle. New fuel filter annually, 3 last season at the end as I thought for sure it was fuel related (didn’t use boat much). Any ideas would be appreciated I’m at a loss.
