20hp Johnson 72
amvaneyk
I had the fly wheel off last week doing some work on it, i put it back on, re torqued the nut then today i was trying to pull it back off and it wont come for anything. I have a puller and an electric air wrench and just wont budge. Any ideas how i can get it off???
zach103
Re: 20hp Johnson 72
What did you torque it too?... have you tried some pb blaster??.. what won't come off the nut or the flywheel?
amvaneyk
Re: 20hp Johnson 72
I torqued the nut to 45 ft lbs. The nut came off fine just can't get the flywheel to come off. I'm using one of those flywheel pullers that has three jaw like things but it wont budge.
Tim Frank
Re: 20hp Johnson 72
Wrong puller if it is the type that the jaws pull under the outer flywheel rim.
You need a puller that uses bolts that thread into purpose-tapped holes in the flywheel.
zach103
Re: 20hp Johnson 72
ok well for all my lawn equipment i stick two screwdrivers behind the flywheel and hold them tight against the flywheel than gently hit the shaft with a rubber mallet.. thats how i do it but maybe someone will chime in with a better way
zach103
Re: 20hp Johnson 72
Oh yah forgot about that one .. use that one
amvaneyk
Re: 20hp Johnson 72
Well embarrassing as it is I didn't read those last few posts till the damage was done. With that wrong puller i was using i bend the teeth on the flywheel and still it didnt come out. does anyone know where i can get a new flywheel used?
