20HP Johnson
muskrat
Re: 20HP Johnson
double check the model number.serial number is to old you will have to call brp..
wbeaton
Re: 20HP Johnson
That model number can't be right. If it's actually CN instead of ON then its a 1982, which I believe is the first year of that motor and is often not listed as a valid model number for whatever reason.
Re: 20HP Johnson
I'll recheck the model#, when I looked at it I wasn't sure if it was "0n" or "cn".
Francispinard
Re: 20HP Johnson
1982 Johnson 20 hp rope start
Hello everybody,
i have a johnson 20hp j20crcnb and i want to instal an electric starter on it. Can I ? Is it possible? actualy it start with a rope.
thank you for the information gentleman !
Francis
hardwater fisherman
Re: 20HP Johnson
you should start a new thread this one is very old. but too your question if they offered an electric start for 20 hp in the same year than yes you can. at the very least you need a starter a soleniod and if your flywheel does not have a ring gear with teeth on it you will have to swap it out. also you will need a starter bracket. and i almost forgot for safety you need a neutral safety switch. so that it wont start in gear.
WIMUSKY
Re: 20HP Johnson
Hello everybody,
Francis
As hardwater stated, please start your own thread as this one is 6.5 years old......
Thanks.
Welcome to the forum.....
WIMUSKY
