hi everyone bought a 20r70e 1970 johnson 20hp outboard on a 12 foot plywood boat. engine seems to be running nicely and has recently had a bit of an overhaul however just does not have the power I would expect from a 20hp engine.
I have adjusted the throttle since last trip out as i was not quite getting full throttle how it was previously adjusted, so that may make it a bit better.
the propellor is not in too good shape, is rather blunt with a few chips in it that could not really be sharpened out. I was wondering how much the state of the propellor affects the output. What affect does putting different sized props on an engine have?
also does adjusting the tilt of the engine help the boat plane better on the water?
if you have any other suggestions that would be much appreciated.
thanks very much for reading!
