'22 Mercury 115 Pro XS, not CT, prop?
undercover500
Engine is 2022 Mercury Pro XS 115hp, the regular version, not the command thrust. Boat is a Tahoe T18, with our current load and gear, we run a top speed of 40.5-41mph at approx. 5300rpm at WOT and fully trimmed out (as far as the engine will allow), engine has the 4 blade 17 pitch SS Spitfire.
On the website for this engine, they list the WOT RPM range as 5,300-6,300rpm. I realize that we are technically at the bottom end of the listed RPM range, but I know that this engine has more to offer. We want to be closer to the 6,300rpm range.
What prop would you recommend? 3 blade, 4 blade, what pitch? I was thinking maybe a 14 pitch 3 blade? Just from my bit of googling, the general rule is that going down an itch in pitch should give us around 200rpm, so if we went down 4 pitches, that would bring us around 6,100rpm. I'm thinking going to a 13p might over rev when we run light, if ever, and to account for if that general rule is not accurate.
The current RPM's and speed are with our typical load, we would rarely run lighter than we did when we got these numbers.
QBhoy
Is the engine height correct on the boat ? Really think something isn’t right here. I’d think you are low on rpms for a set up like that and only 17” pitch. What gauges do you have ? Are they accurate. You’re showing 1% slip there. Something isn’t right for sure.
