23 foot cruiser 200HP oceanpro evinrude fuel consumption
malta
Hi all.
so i bought this boat and have had in the sea for the last month or so. being a bit of a statistics nerd, i keep a log of the distance, time and fuel i have put into the tank, and it seems that i am consuming 0.66 litres per minute - my average spead would be around 15 knots, at about 3,000 revs. I admit i am used to a speadboat, so maybe i am going a little too fast for optimal fuel efficiency.
How does my consumption compare to anything similar you may be running?
Cliff in Malta.
Will Bark
Re: 23 foot cruiser 200HP oceanpro evinrude fuel consumption
Don't know about the liters but the rule of thumb is 20 gallons per hour at WOT which I guess would equate to .33 gallons per minute; but you are not running at WOT. Others will probably chime in on this.
malta
thanks for the reply, but i am not familar with the term WOT.
20 US gallons translates to some 75 litres, which implies a consumption of 1.25 litres per minute, which is double what i am burning.. is that right? sounds like quite a lot.
Chris1956
Cliff, rough math (4L = 1 Gal) shows .66L/minute is about 10Gal/hour, which is not bad for that boat. At full throttle (WOT), that motor can burn 20Gal/hour.
malta
thanks all.
it will make me feel better as i pour litre after litre into the tank to know i am burning normal levels of liquid gold!
Cliff
