tmetals
- Jul 31, 2017
- 3
1999
bayliner capri 1800 bow rider
mercury force 120 outboard
long story short.
none of the factory gauges or switches were working in my boat. i ordered new gauges and led latching as well as momentary 5 pin switches and some bosh 5 pin relays,
i fired up the boat after sitting through the winter. everything seemed as it was when it was parked last year.
i traced all wires, and labeled them individually. i ran through the bayliner owners manual wiring diagram, as well as the mercury wiring and made sure things made some sense to me. once i felt i had a grasp on what i was doing i replaced the factory 2 pos switches with the puch button. then i did the gauges.
now here is where things became weird.
i removed the factory 6 pin ignition switch. replaced it with a 2 installed a latching 5 pin switch for the choke, a momentary 5 pin for start , hooked up to a bosh style relay.
it took me about 4 hrs but i got everything to work in series.
untill i tied it all together with a new fuse block.
the boat cranked all day long but would not fire. turns out the ground and the magneto ground are not the same "GROUND"
and they technically work as a switch together when the key is off and on.
just for ease i un-hooked the magneto ground BK-Y wire from the fuse block and let it hang.....the boat fired up right away, but would not turn off at the key.
i tested the voltage from the magneto ground BK-Y, and i am receiving 240V from the magneto ground wire. when i hooked up the original 6 pin ignition switch, everything works as it should. on/off, start/stop, choke.....
but when the motor is running and at idle, when i test the back pin on the magneto ground it is reading 238-240V. this seems like a massive amount of power flowing through some 16ga wire and a switch.
does anyone know what the voltage should be at the ignition switch with the boat running?
i have been on this for over a week, and our annual 10 day dessert lake trip is two working days away and i am running out of options and sleep.
does this seem like a safe amount of voltage to be hooked up in a 12v fiberglass boat?
I am aware the magneto generates power. up to 20,000V , but is it normal to have this kind of power at the back of a dash switch?????
please help...
thanks
long story short.
please help...
thanks
