24' pontoon prop Help please
Tatordirect
Hello everyone..... I have a 24' playbuoy model PB Calypso elite 2423. Weight 1680. I have a spun prop. Motor is a Mercury 50 hp year 2002 elpto. Serial number ot457323 max rpm 5500 model 1050412zd. Gear hard to read sticker 12:22 1.83:1. Boat mph and rpm not working. Took old prop off marking on bushing F12x10 5 p. Thier is a number on propeller can't make it out. Need to replace propeller web sites asking a lot of info I have no clue. It has 13 splines on average 4 to 6 people ride it. I prefer aluminum for cheaper price low funds. If anyone can help with whatever I need to type in to get proper prop. If you need any other info please ask.
Thanks Have a great day.
BatDaddy1887
Here is a popular Mercury prop selector site. Get a prop that takes the inserts, which have almost replaced rubber-hub props, that way you can have a second insert on board in case you hit a rock and break the current insert. This would act as a spare prop if need be. It also allows you to change pitch with other props for certain activities.
steelespike
It may be possible for a prop shop to rehub and repair the prop for less than new.
