Re: 24 volt trolling
Hi Rob<br />Always use deep cycle Marine Batteries for your troller. A automotive starting battery is not designed to be charged and discharged over and over and it will have a short life if used this way. 24 volts is the way to go, as it will make better use of the power available and uses less AMP's for longer running.
