meantobe63
- Feb 17, 2011
- 83
Bought the boat a year ago and tachometer didn’t read correctly. Mercruiser with Alpha one 2.0 gear ratio. With the prop that came on it, a 16x14p, I’d only get 16-17mph with 4 adults and 3 kids. This year with the new tach, I’ve ran this prop again and getting 4000 rpm. At that rpm and speed, calculator showing a 40% slip. With a 14.5x15p at 3800 rpms I got 20mph, and a 16x16p at 4000 rpms I got 18-19. With all 3 of those props I’m seeing the same 40% slip. Now I understand I should be at 4800 rpms and am not achieving that, (going to address that this week), but either way I have extreme prop slip. I’ve also had a lot of issues with blow out, but this last time out shifted all the weight I could to the rear. When I got the boat, from water line down the pontoons were primered and extremely rough, and even the parts that weren’t painted were extremely rough. In the last couple weeks I’ve sanded ALL the rough aluminum and all the paint off to silky smooth. All except for bottom that is sitting on bunks. Took it out yesterday with the original 16x14p and saw no difference. Looked smoother in water, but speed not changed. I understand that the very bottom 12” has the most drag in water, but still can’t see a 40% slip. Pontoons aren’t in greatest shape, so I have installed drains to make sure they aren’t full of water.
What else could be the problem?
Oh yeah, original “top speed” for boat was listed as 26mph. I’m not trying to make this in to a Playcraft, but would like to get closer to what it’s supposed to be.
